Author Topic: Sharp GP2D120XJ00F cable?  (Read 4862 times)
Offline ConscriptedTopic starter
  • Helpful? 10
« on: May 05, 2008, 05:27:48 PM »
Hello again. I received my sharp IR sensor from digikey today. Unfortunately in my wisdom I didn't order a cable to connect it to anything. Anyone have any success making one of these? I know I could buy a cable premade but I would rather not pay shipping again on a 2 dollar part. Any chance they sell this cable at a hobby store?
Conscripted
« Last Edit: May 05, 2008, 05:39:23 PM by Conscripted »
Offline pomprocker
Re: Sharp GP2D120XJ00F cable?
« Reply #1 on: May 05, 2008, 05:59:22 PM »
youll never find it at a hobby store.
you might as well order it premade otherwise youll just have to order the connector for the sharp ir end of it.
Offline superchiku
  • cooll
« Reply #2 on: May 06, 2008, 01:18:53 AM »
just cut out th jt connector and solder in the wires for the connectors u like
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline bukowski
« Reply #3 on: May 06, 2008, 10:14:28 AM »
yeah, or you could just solder straight to the pins on the back of the connector. When you are looking at the front with the connector pointed down, it should go Va, GND, VCC.
  • Helpful? 10
« Reply #4 on: May 06, 2008, 08:17:04 PM »
So it should go like this? If so I'll just solder directly to the pins. Maybe with half a servo extension cable.
« Last Edit: May 06, 2008, 08:17:53 PM by Conscripted »
Offline bukowski
« Reply #5 on: May 07, 2008, 10:23:19 AM »
yup
Offline Del
« Reply #6 on: May 07, 2008, 10:44:30 AM »
What I did, is I bent the pins of the GP2D slightly, and then I fit the pins
into individual Female headers.
That way, I could then just plug the GP2D into the usual 0.1" Male headers.
Depending on the physical size of the Female pins that you use,
you may have to trim the white guard on the GP2D.
HTH
« Last Edit: May 07, 2008, 10:46:44 AM by Del »
Offline superchiku
  • cooll
« Reply #7 on: May 07, 2008, 02:46:55 PM »
what ever u do make it clean dont mess up the board solderings
JAYDEEP ...
  • Helpful? 10
« Reply #8 on: May 07, 2008, 05:20:45 PM »
Thanks for the information guys! I think i have the information I need.
« Reply #9 on: May 17, 2008, 05:15:04 PM »
It's really sad they don't always sell these with the wiring. You think, 'wow its cheaper at this site!' but in reality its 'cause they skimped on the wires . . . several other members here fell for it too - you aren't the first!
Offline Tsukubadaisei
« Reply #10 on: May 17, 2008, 09:04:17 PM »
Strange... cant you just order with the connectors(not the cables)? When I buy those sensors they come with the connectors and datasheet.
  • Helpful? 10
« Reply #11 on: May 17, 2008, 10:04:33 PM »
I ordered mine from digikey. No cable no data sheet.  :( I'll solder on half of a servo extension cable once I get to that point in my project. I should be able to get it to look ok.
Conscripted
« Reply #12 on: May 24, 2008, 08:14:59 AM »
I always buy mine from Acroname.
