Author Topic: BlueSMiRF blues  (Read 4629 times)
BlueSMiRF blues
« on: May 12, 2008, 11:09:00 AM »
I accidentally bricked my bluesmirt setting the mode to auto master instead of slave. now the computer cant see it.
anyone know a way to reset it to factory settings?
Re: BlueSMiRF blues
« Reply #1 on: May 12, 2008, 01:36:00 PM »
set PIO4 high for 2 seconds upon power up is required to reset to factory defaults
what are you using the bluesmirf for?
Re: BlueSMiRF blues
« Reply #2 on: May 12, 2008, 04:29:15 PM »
yeah i tried setting PIO4 high with 3.3v but it is soldered to ground, so it didnt work.
I read the manual and tried the things they mentioned,, including an rs232 cable from pc to bluesmirf
i'm using it for UART, and working on doing my wireless programming using the watchdog timer for a reset.
« Last Edit: May 12, 2008, 04:31:06 PM by pomprocker »
Re: BlueSMiRF blues
« Reply #3 on: May 13, 2008, 08:42:27 PM »
I had the wrong pin
if you look on the back of the bluesmirf, PIO4 is on the side with more pcb traces, 3rd one away from the blue antenna.
even though its grounded, you hold 3.3v to it and then power it up. then you just have to toggle it three times by tapping the voltage to that pin. you have as much time as you want to toggle it.
this will do a factory reset of the bluesmirf.
