Author Topic: Circuit Check?  (Read 3045 times)
Offline MUDSKIPTopic starter
Circuit Check?
« on: May 17, 2008, 04:24:07 PM »
This is my very first circuit...I'm trying to design a board for personal use, so I have very specific little slots, as you'll soon see...It uses a ATmega 168 microcontroller. I haven't put in the serial port thingy yet; Also, I've left a couple of Digital ports not plugged into anything, which isn't terribly bad, just a waste. :P
Could somebody do me a favor and check over my circuit for anything terribly wrong? And then maybe some tips on how to make it better? :P
Again, this is for personal use; I know I'm not going to plug this thing into another controller and combine the 2, so I'm not including an ISCP plug. Also, I know I can also use the TX and RX plugs as digital ports, but I'm choosing not to simply because I have plenty of other digital ports I can use. Also, I'll be running lots of tests, and will need to send serial data to see the data.
« Last Edit: May 17, 2008, 04:30:37 PM by MUDSKIP »
Re: Circuit Check?
« Reply #1 on: May 17, 2008, 06:04:17 PM »
*bump*
Re: Circuit Check?
« Reply #2 on: May 17, 2008, 08:58:04 PM »
...anybody?
Offline AndrewM
    • I Am.  When?
Re: Circuit Check?
« Reply #3 on: May 17, 2008, 09:52:38 PM »
A little patience goes a long way.  I, for one, do not have eagle loaded on my computer at home, so can;t even think to look at what you came up with until I meander into work Monday afternoon.  Creating a jpg or png image of your schematic or board layout would probably go some way in getting you a quicker response.
blog: www.iamwhen.com
Saving the world from humanity one robot at a time.
Re: Circuit Check?
« Reply #4 on: May 24, 2008, 08:05:58 AM »
Yea the best way to get a schematic reviewed is post an image of it. Also, wait more than 2 hours for a reply :P
So how do you plan to program it, then?
Offline SixRingz
  • Bit's and pc's = Robot.
    • ManMachineSystem
Re: Circuit Check?
« Reply #5 on: June 02, 2008, 05:58:23 PM »
Well, I'd love to help you but I'm more of a "trial and error" kinda guy when it comes to electronics. My rule of thumb: If the circuit smells, you're in trouble.  :o
Grounding things properly means burying them in the backyard...
