Author Topic: Optocoupler(4N33)  (Read 7561 times)
Offline rahulmagooTopic starter
Optocoupler(4N33)
« on: June 10, 2008, 03:19:10 AM »
hello,
I have a questions regarding Optocoupler..
I am making a simple line following robot, instead of using ULN 2803(darlington array) and relays can I use optocoupler(4N33).If yes could anyone please help me in using it as i could'n understand it completely from its datasheet.
Re: Optocoupler(4N33)
« Reply #1 on: June 16, 2008, 12:47:42 PM »
What is it being used for?
« Reply #2 on: June 28, 2008, 01:24:52 PM »
I am using my optocoupler(4N33) to drive my motors.
Offline izua
    • izua electronics
« Reply #3 on: June 28, 2008, 01:48:01 PM »
you can't use an optocoupler to drive motors. 4n33 has a collector current of 150, small motors can sink even 500 mA at startup.
you will have to buffer its output with a transistor or some logic gates
« Reply #4 on: June 28, 2008, 02:02:23 PM »
For that can i use a darlington array(ULN 2803).
Offline izua
    • izua electronics
« Reply #5 on: June 28, 2008, 11:01:51 PM »
remember, ULNs are inverted logic, or low-side switching. You will have to supply + to your motor, and connect the other wire to the ULN. Also, check if you wired your opto correctly using a led. Finally, check if the rest of the circuit works correctly, by removing the optocoupler (if in a socket) and shorting the pins of its output. This way, the rest of the circuit will see as if the optocoupler is "open". Last, do a sanity check to see if you haven't messed up the led polarity :)
