Author Topic: controllers and transmitters  (Read 4668 times)
Offline Ro-Bot28Topic starter
« on: July 27, 2008, 04:12:02 PM »
does anyone know where i could buy Remote Control Transmitters and recievers?
Offline izua
    • izua electronics
Re: controllers and transmitters
« Reply #1 on: July 27, 2008, 05:27:36 PM »
Almost any electronic shop has IR leds and some TSOP receivers from Vishay.
If not, ebay is a good place to start.
« Reply #2 on: July 27, 2008, 06:04:47 PM »
ok thanks
« Reply #3 on: July 27, 2008, 07:21:19 PM »
i also have another question..
im working on a robot design.
its a 4wheeled platform (remote controlled), but i want to put a camera or somthin on the front so i can "see what it sees"
similar to the spy gears video car
but the problem is that i dont know where to start with this camera or how to set it up or how i can get the feedback
and i also want to kno the avr. cost of the camera setup
Offline izua
    • izua electronics
« Reply #4 on: July 27, 2008, 08:33:15 PM »
This is what you want.
You plug it in a TV, tv tuner card or portable player and there you go, instant camera.
Of course, it's the worst choice for image processing, but then again, that's not a beginner topic.
Offline Bajanick
« Reply #5 on: July 27, 2008, 10:33:35 PM »
I have that same camera and just mounted it on a rover I built. It has an ok picture but its range is very limited.
« Reply #6 on: July 28, 2008, 09:35:25 AM »
how far is the range of yours?
« Reply #7 on: July 28, 2008, 04:17:24 PM »
I also have one
Maximum of 100 ft. range for me - it depends on the surroundings also
Offline izua
    • izua electronics
« Reply #8 on: July 28, 2008, 06:17:16 PM »
Heh, I assumed you wanted a low cost solution since you were asking about the cost. The camera I mentioned is indeed a low cost solution, cheapest I know of. Range isn't very good, I haven't been able to go past two walls indoors. Image quality also suffers (at some point when camera battery was running low, I got only b/w images).
If you would like something of higher quality, a CMOS camera would be much better suited. Of course, there's still the problem of transmitting and encoding that data.
