Author Topic: Breadboard Connection  (Read 2561 times)
Offline Jon_and_KidsTopic starter
« on: August 01, 2008, 11:32:05 AM »
We are trying to make the $50 robot using a breadboard. It seems pretty straight forward, but I am confused on how to make the programmer pin connection. I am using the AVR MKII programmer. Can I make a 6 pin connection using the male pins like the 3b instructions or will I need to use connector wires from the programmer cable to the processor? ???
Offline izua
    • izua electronics
Re: Breadboard Connection
« Reply #1 on: August 01, 2008, 12:23:24 PM »
you can fix wires in the programmer's connector, and stick the wires in the corresponding pins at the other end. it's a bit tricky to make a ISP6 male connector on a breadboard, so it's just plain easier to take the wires from the programmer individually and put them where needed.
that's the way I do it - Ii have a home built programmer and it doesn't even have a 6 pin connector, just individual wires for each signal.
