Author Topic: bluetooth connectivity  (Read 2765 times)
Offline ratcatemeTopic starter
« on: August 09, 2008, 02:29:57 AM »
Hi i have just purchased a axon and i want to know can i use this bluetooth Module http://www.robotshop.ca/ProductInfo.aspx?pc=RB-Spa-34&cf=273941a1 and connect it directly to rx and tx on the UART of the axon or do i need to put a rs232 shifter in the middle. i am just learning robotics and i have bought the axon as a way to make learning easier and i want to learn how to interface via bluetooth.
Scott.
Offline izua
    • izua electronics
Re: bluetooth connectivity
« Reply #1 on: August 09, 2008, 06:46:05 AM »
Nope. Axon has UART stages, the module has UART stages. No RS232 shifting is needed.
However, the module has 3.3v signaling, which might be a problem (not sure if axon uses TTL levels or 3.3v levels)
« Reply #2 on: August 09, 2008, 05:33:26 PM »
thanks for the reply looking at the data sheet it has 3.3v output down by the usb i can use now i just have to save up some money for it and one for my laptop
Scott.
