Society of Robots - Robot Forum
Robot Tutorials
FAQ
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Squirrels have fuzzy tails.
Home
Help
Search
Login
Register
General Misc
Misc
Axon, Sensors, and Robots oh my
Print
Author
Topic: Axon, Sensors, and Robots oh my (Read 4185 times)
MarkBrown
Full Member
Helpful? 0
on:
August 15, 2008, 02:17:32 PM »
I am not sure if this is the right place for it, but hopefully someone will correct me. Before finding this site, I was planning on buying one of those Lego Mindstorms to learn about robotics. After alot of reading and much consideration, I have decided I would rather spend that 250+ on the Axon and sensors and building materials.
Regarding the Axon, I am wanting to purchase one for now and use it to build my robots due to its simplicity. This way I can concentrate on the building, power and programming of the robots. Once that is down, I plan to either build the $50 Robot unit to perminatly use. Will this work or are there enough differences in the programming that it might lead to more trouble than it is worth?
Regarding the sensors, I would like to stock up on some sensors for the next few project I am going to work on. Can anyone give suggestions on which brands of sensors are suggested? I know I want to get at least 1 ping))), but as far as compases and other standard sensor types, there are so many brands and adds that I was hoping to tap into your knowledge and experience.
Thank you,
Mark Brown
Logged
It is human nature to confuse genious with insanity
http://marksproject.blogspot.com/
Afroman
Expert Roboticist
Full Member
Helpful? 4
Re: Axon, Sensors, and Robots oh my
Reply #1 on:
August 16, 2008, 01:16:13 AM »
I think the maxbotix ultrasonic rangers will work a lot better with the Axon because they have rs232 and analog outputs
http://www.sparkfun.com/commerce/product_info.php?products_id=8502
Logged
MarkBrown
Full Member
Helpful? 0
Reply #2 on:
August 16, 2008, 01:25:38 AM »
Thanks, I will look into those.
What I am wanting to do though is use the Axon for testing and initial setup and then once all is setup, substitute a cheaper MCU when I finish the bot, as I can't afford to by an Axon for every project. Is there any down fall to doing this, other than not using an awesome ass MCU with the finished bot?
Logged
pomprocker
Supreme Robot
Helpful? 16
Sorry miss, I was giving myself an oil-job.
Reply #3 on:
August 16, 2008, 01:31:26 AM »
I wrote a tutorial on using the Parallax Ping with the $50 robot board.
http://www.societyofrobots.com/member_tutorials/node/174
although untested with the Axon, it should work in theory with minor modification.
Logged
Blog:
Nerd Stuff - Programming, Electronics, Mechanics
MarkBrown
Full Member
Helpful? 0
Reply #4 on:
August 16, 2008, 03:45:38 PM »
Thanks very much. This is going to be a great help for one of the robots I am designing. I planned to use sonor on it because it will be an outside robot and from what I have read, sonor is usually a more reliable way of detecting object outside in the sun.
Logged
Iron Man
Full Member
Helpful? 0
Reply #5 on:
August 19, 2008, 09:18:04 AM »
you could always make your control boards easily removed so that you can just move one board around to many different chasis.
Logged
paulstreats
Guest
Reply #6 on:
August 19, 2008, 05:25:36 PM »
Out of experience one of the sonar modules like the maxbotics type mentioned above is a lot easier to use. They output actual distances (they do the maths on the module) to the mcu whereas as far as i can see the parallax ping just lets you know when the signal is received leaving you to do all of the mathmatics and converting sound speed data into a useable distance (meaning having to use timers etc..).
Logged
Print
General Misc
Misc
SMF spam
blocked by CleanTalk
