Author Topic: Check my schematic  (Read 2876 times)
Offline MadMaxTopic starter
Check my schematic
« on: August 19, 2008, 04:36:54 AM »
Yes, I ask of you exactly what the title says: please check out my schematic and see if everything is fine. I'm pretty good at programming, but entirely new to electronics.
It's a fairly simple schematic, so ye ol' veterans won't have any problems spotting any errors.
Schematic (PDF)
Board (PDF)
EDIT:
in the schematic, SV10 is a header that is connected to a 5V regulator,
1 = +/- 6V (directly from battery)
2 = GND
3 = +5V
Thanks in advance
« Last Edit: August 19, 2008, 06:36:26 AM by MadMax »
Offline izua
    • izua electronics
Re: Check my schematic
« Reply #1 on: August 19, 2008, 06:04:40 AM »
No power caps for the PIC.
I assume the 8 connectors are servo connectors, you should allow for a different power supply for them. Connecting them to the PIC's VCC directly might not be such a good idea (esspecially if you intend to run your pic at 3.3V for example :P)
« Reply #2 on: August 19, 2008, 06:36:09 AM »
Oh sorry, I forgot to explain,
2 = GND
3 = +5V
I'll update the first post.
« Reply #3 on: August 23, 2008, 08:11:41 PM »
Looks ok to me.
You may want to run regulated power to some of the headers for various sensors.
