Author Topic: programming for 128*64 LCD with atmega32  (Read 5083 times)
Offline SalmanTopic starter
« on: August 20, 2008, 04:52:34 AM »
I have been working on interfacing a LM12864DDY to ATMEGA32 microcontroller but have been having some problems. Has anyone got a sample of code using C language that they would be willing to share?
Re: programming for 128*64 LCD with atmega32
« Reply #1 on: August 23, 2008, 08:19:28 PM »
Can you provide us a datasheet or more info on your part?
« Reply #2 on: August 26, 2008, 09:21:52 AM »
http://www.topwaydisplay.com/Pub/Manual/LM12864DDY-Manual-Rev0.1.pdf
Sir this is the link to the datasheet of lm12864ddy graphic lcd screen.
thank u for ur reply
Offline TrickyNekro
  • Hardware and Firmware Designer
    • The Hellinic Robots Portal
« Reply #3 on: August 26, 2008, 09:32:41 AM »
It must be KS0107 compatible.... if you have some code for that, try it!
Regards
« Reply #4 on: August 28, 2008, 08:18:14 PM »
Thats a horrible datasheet, I can barely understand it . . . can't really make out what the input pins do or what signal format they require.
Other than your forum post here (and a copy of it at multiple other forums), google has never even heard of this LCD.
I think you'd be better off trashing this LCD and getting a serial based LCD. You'll save yourself days of painful frustration.
