Author Topic: analogRead  (Read 5374 times)
Offline TrumpkinTopic starter
analogRead
« on: August 22, 2008, 07:09:21 PM »
Hey people, when I try to compile this code I get this error "undefined reference to analogRead". Is there a library or something I'm supposed to include?
/* Blinker Demo */
/* Include useful pre-defined functions*/
#include <avr/interrupt.h>    // Defines pins, ports, etc to make programs easier to read
#define F_CPU 100000UL       // Sets up the default speed for delay.h
#include <util/delay.h>
int IR_pin = 5;
int val = 0;     //a variable to store IR value
int IR_thresh = 100;
int main()
for ( ;; )
  val = analogRead(IR_pin);
  if (val < IR_thresh)
  DDRD = _BV(PD7); // enable output on port D, pin 7
    PORTD = _BV(PD7);
    _delay_ms(1000);
    PORTD &= ~_BV(PD7);
    _delay_ms(1000);
  return(0);
Robots are awesome!
Re: analogRead
« Reply #1 on: August 22, 2008, 10:12:48 PM »
Where did this line come from?
Anyway, the error is because you need to declare what analogRead() is before you use it.
For example:
void analogRead(int pin);//declare here, then define it somewhere else
int main()
Offline pomprocker
Re: analogRead
« Reply #2 on: August 22, 2008, 11:07:35 PM »
you can either just declare, or declare and initialize.
<data_type> <variable>;
or
<data_type> <variable> = <number to initialize with>
ex:
int val;
or
int val = 0;
Re: analogRead
« Reply #3 on: August 27, 2008, 10:02:50 AM »
I got the code to compile and download on to my microcontroller but the LED just blinked randomly.  :-\ I wanted the LED to blink when my hand got close to the Sharp IR. I changed the code a bit, heres what I want it to do
 auto calibrate
 blink the LED to let you know that it has calibrated
 when an object gets within the calibrated range have the LED blink
I probably have a lot of things wrong since I'm not very good at programming yet.
/* Blinker Demo */
#include <SoR_Utils.h>
int IR_pin = 5;
int val = 0;
int main()
//automatically calculates threshold value before run
int IR_thresh=a2dConvert8bit(IR_pin);//sensor reading
PORT_ON(PORTD, 7);
_delay_ms(5000);
PORT_OFF(PORTD, 7);
_delay_ms(5000);
       for ( ;; ) //loops forever
  val = a2dConvert8bit(IR_pin);
  PORT_ON(PORTD, 7);
  _delay_ms(1000);
  PORT_OFF(PORTD, 7);
  _delay_ms(1000);
  return(0);
« Last Edit: August 27, 2008, 10:04:51 AM by Trumpkin »
Robots are awesome!
Re: analogRead
« Reply #4 on: August 27, 2008, 10:55:15 AM »
Heres the pseudo code
Read value of Sharp and store in variable "distance"
If distance is more than threshold Then  // I wrote more because the Sharp IR returns a higher value the closer you are
        Flash_LED
Else
         Turn_LED_Off
Endif
Loop
The actual C code is pretty simple , the most complicated part I could think of is getting the values of the Sharp IR sensor and see the values for close objects and the values for further. If I remember correctly the closer u are the higher the value - but I am not sure , the last time I used a Sharp IR sensor was in that electronics book combination lock.
