Author Topic: Robot Vision  (Read 4936 times)
Offline CommanderbobTopic starter
  • Embeddedmicro.com
    • Embedded Micro
Robot Vision
« on: August 29, 2008, 12:50:35 AM »
I want to start using a camera in my robots, however I am having a hard time finding one. I will be using an AVR32 with 32K of RAM. I don't need a high res camera as one image should fit in ~25K. I know SparkFun sells some cheap ones but looking on their forum people don't seem to have very good luck with them. I would like a simple camera, not a CMUcam. Mouser and Digikey don't sell anything like this.
What has been used? What works?
Thanks,
Justin
Offline benji
Re: Robot Vision
« Reply #1 on: August 29, 2008, 03:37:02 PM »
oneday i wanted to do the same thing and i guess the gameboy black n white camera is a good way to start
good ol' BeNNy
  • Embeddedmicro.com
    • Embedded Micro
Re: Robot Vision
« Reply #2 on: August 29, 2008, 03:47:21 PM »
Thanks for the tip! I kinda wanted a color camera though. So I can track a colored object easily, or pick out a coke can.
  • Embeddedmicro.com
    • Embedded Micro
Re: Robot Vision
« Reply #3 on: August 30, 2008, 12:04:38 AM »
Been looking around and it looks like it is quite a challenge to get these things working.
How about http://www.electronics123.com/s.nl;jsessionid=0a010b421f432788cfc082ba4090a792b0e949d38c16.e3eSc38TaNqNe34Pa38Ta38SaN10?it=A&id=67&sc=8&category=241 it is the same camera the AVRcam uses. They managed to get an ATmega8 to read the camera AND do image processing! I don't know how because they only have 1K of RAM. You could note even store a single image.
The actually sensor can be found here http://www.cs.cmu.edu/~cmucam/Downloads/ov6620DSLF.PDF
My main question is how can the AVR keep up? Does the camera have a built in buffer?
  • Embeddedmicro.com
    • Embedded Micro
Re: Robot Vision
« Reply #4 on: August 30, 2008, 11:34:48 AM »
http://www.robozes.com/inaki/dproject/
It has been done!
I am going to order a c3088 camera and try it with my AVR32.
  • Embeddedmicro.com
    • Embedded Micro
Re: Robot Vision
« Reply #6 on: September 01, 2008, 06:13:37 PM »
Thanks, but that is what I don't want. I want to connect to the camera directly, not though another microcontroller. You get better data rates with the parallel interface. The C3088 is an image sensor on a PCB with a lens. You get the parallel interface, smaller size, and lower costs. Also I don't was to use a computer or remote control.
Once I buy it and get it working I'll post how it went.
