Author Topic: Help with schematic  (Read 2525 times)
Offline izuaTopic starter
    • izua electronics
Help with schematic
« on: August 29, 2008, 03:19:23 PM »
Hi, please check this schematic.
It's a breakout board for atmega 128.
What I really want to know is if the programming headers are correct, and if the chip in the left (FT232RL) is wired right (for a self powered device). The rightmost header (P-USB) is actually connected to a USB device connector, which has the pins, when in line as V+, GND, D+, D-. I'm not aware if the converter needs grounding if the 3.3 is not used. DS says it uses an internal oscillator.
Also, what should I do with the PEN pin on the atmega?
I have been trying to post this for 20 minutes and smf kept telling me that i have already posted this message.
edit. An Error Has Occurred!
You already submitted this post! You might have accidently double clicked, or tried to refresh.
« Last Edit: August 29, 2008, 03:29:09 PM by izua »
Re: Help with schematic
« Reply #1 on: September 01, 2008, 03:40:53 PM »
yeap
On the right? :P
I haven't used it before, but it looks ok on a quick glance . . .
PEN is a programming enable pin for the SPI Serial Programming mode. I *think* you need to ground it but check the datasheet to make sure first.
Offline Trumpkin
« Reply #2 on: September 01, 2008, 04:12:39 PM »
don't you need to connect 3.3v OUT to GND through a 100nf capacitor?
« Last Edit: September 04, 2008, 01:40:14 PM by Trumpkin »
Robots are awesome!
