Author Topic: SRF05 Wont work with Picaxe 28x1!!  (Read 3828 times)
Offline MaltiKTopic starter
« on: September 16, 2008, 02:43:30 PM »
I soldered everything up correctly as supposed to, and when I plug in the power to the picaxe, after 7-10 seconds, the SRF05 board and everything gets extremely hot... Did it burn out? How can I see if the SRF05 still works?
Warranty
Re: SRF05 Wont work with Picaxe 28x1!!
« Reply #1 on: September 19, 2008, 08:30:12 AM »
Sounds like you shorted something or applied a really high voltage. Check the wiring really carefully, then power it up (starting from a low voltage) and check everything with your multimeter.
If it got really hot, its probably fried though . . . see any visual damage?
« Reply #2 on: September 20, 2008, 08:45:42 AM »
nope no visual damage... I am going to go to the workshop today to measure it
Warranty
