Author Topic: connect 2 different software codes  (Read 3311 times)
Offline robotaTopic starter
« on: September 19, 2008, 06:09:51 AM »
I have 2 codes that was write in 2 different software
I want that my computer can run this 2 codes despite that this 2 codes are made in
Different software
Who I can do this ?
Offline pomprocker
Re: connect 2 different software codes
« Reply #1 on: September 19, 2008, 11:57:26 AM »
I'm not sure I understand your grammer  ???
Offline SciTech02
  • Life's but a green duck with soy sauce. -MegaHAL
« Reply #2 on: September 21, 2008, 08:20:51 PM »
You say these codes are written in two different "software", do you mean they're written in two completely different programing languages?  If this is the case, you should be able to run them at the same time (you can run a java app in an HTML code, so it should be possible).  I don't know how to do this, but one of the "big guys" here might know how.  Otherwise, you would have to compile one of the programs ("translate" it to the language of the other program and combine them into 1 code).  More information is needed for a meaningful answer (what software did you make the codes in?).  We can solve this problem if we know all the facts.  :)
Check out the Evolution Robotics, ER1 robot, and ERSP Resource Page: http://www.societyofrobots.com/member_tutorials/node/336
Offline Kohanbash
« Reply #3 on: September 22, 2008, 09:00:45 PM »
HI
What programming language did you use?
What platform are they running on?
Do they need to communicate with each other?
