Author Topic: How to connect Dimension Engineering ACCM3D Accelerometer?  (Read 4052 times)
Offline Razor ConceptsTopic starter
    • RazorConcepts
« on: October 16, 2008, 03:27:16 PM »
I just got the Dimension Engineering ACCM3D Accelerometer and saw that it has pins I dont have a connectors for. What kind of connector will I need?
http://dimensionengineering.com/DE-ACCM3D.htm
Re: How to connect Dimension Engineering ACCM3D Accelerometer?
« Reply #1 on: October 16, 2008, 03:36:17 PM »
Offline frank26080115
« Reply #2 on: October 16, 2008, 03:41:32 PM »
It plugs into a DIP chip socket
It is designed to fit in the DIP-16 form factor, making the DE-ACCM3D suitable for breadboarding, perfboarding, and insertion into standard chip sockets. To keep things as simple as possible, there are only 5 pins - two for power, and three for the X, Y and Z analog outputs.
« Last Edit: October 16, 2008, 03:42:13 PM by frank26080115 »
Offline Qubix
« Reply #3 on: October 17, 2008, 05:55:23 AM »
Yeah a 16 pin DIP socket is what you want, also it will go straight into a bread board for prototyping your circuit. :)
http://robots.ie  - Ireland's robot site
