Author Topic: My $50 Robot(s)  (Read 2978 times)
Offline Razor ConceptsTopic starter
    • RazorConcepts
My $50 Robot(s)
« on: November 05, 2008, 08:33:08 PM »
With much help from airman00 I built my $50 robot with the mega168, I didnt want to bother with the photoresistor stuff so I made a wall follower. Will post videos later.
I like how the MCU board only costs about $6 to build, so I can go crazy making different boards and stuff.
Anyways after building that I decided to build a tiny board with a attiny25. Here it is, just finished it tonight:
Only 6 I/O pins, but should work with small stuff and other non-robotic projects (LED driver, RC failsafe, etc).
By the way, is a 5v regulator needed when using a 4 cell NiCd battery? Right now for the $50 board my battery goes through the voltage regulator, but to save space on the tiny25 board I didn't bother with any. Also, will it be alright if I have things like servos or sensors plugged into the ports used for programming? For example say I have a sharp sensor plugged into port PB4. PB4 connects to one of the 6 ISP programming pins. Is it alright if I leave the sharp sensor plugged in, and program using the AVR ISP?
Re: My $50 Robot(s)
« Reply #1 on: November 05, 2008, 08:43:30 PM »
you finally found a use for AOL CDs  :P
4 Cell rechargeable is 4.8V while a regular 5V regulator needs at least 7V to operate properly and a low dropout regulator needs 6V.
Depending on how much current the stuff connected draw , then you should pull it out. Small things like a sharp IR would not affect it but I think servos might draw voltage from the ISP programmer(which is bad)
Offline izaktj
Re: My $50 Robot(s)
« Reply #2 on: November 05, 2008, 10:09:31 PM »
Nice and clean robots  :D
Re: My $50 Robot(s)
« Reply #3 on: November 08, 2008, 11:20:31 AM »
Nope, you'll damage something. If one device says 5V and the other device says 0V, you end up with a short.
