Author Topic: Please look at this schmatic  (Read 2587 times)
Offline ross75Topic starter
« on: November 07, 2008, 06:27:29 PM »
Hi, I just built the board for the $50 robot and it worked, my first ever electronics project so i was suprised!. I figured why not try and use a diffrent chip with more memory and I/O so i got a atmega644. The pins are diffrent so i looked at the data sheet and made my own drawing of what i think the circuit should look like and also added in a rs232 shifter. Can someone take a look and see if i have the right idea? The circles are where wires attach to each other and the components. It's not the best drawing but again im new here.
« Last Edit: November 07, 2008, 06:28:58 PM by ross75 »
  • Helpful? 111
    • Webbot stuff
Re: Please look at this schmatic
« Reply #1 on: November 07, 2008, 08:13:01 PM »
Looks like all your IO pins are connected to the regulated 5v supply. If you want to drive current hungry devices like motors/servos then they should have a seperate power supply.
« Reply #2 on: November 07, 2008, 08:36:00 PM »
Thanx, that shouldnt be too hard. It's just a second battery and the + goes to one set of ports instead of the 5v and the ground is shared right? did everything else look ok?
  • Helpful? 111
    • Webbot stuff
« Reply #3 on: November 08, 2008, 10:21:33 AM »
« Reply #4 on: November 13, 2008, 01:18:09 AM »
Attached are two images of my 644 board (and actually my first Axon prototype). I lost my schematic, sorry!
Hopefully these should help you a bit.
