Author Topic: question about some parts  (Read 2381 times)
Offline ross75Topic starter
« on: November 10, 2008, 02:10:17 PM »
Offline Trumpkin
Re: question about some parts
« Reply #1 on: November 10, 2008, 08:50:44 PM »
Will this part work instead of a serial rs232 shifter?
No, I don't think so.
Robots are awesome!
Offline Commanderbob
  • Embeddedmicro.com
    • Embedded Micro
« Reply #2 on: November 11, 2008, 04:40:00 PM »
You should be able to use that instead of a rs232 level shifter. It is a serial to USB converter. It uses a generic USB driver to emulate a serial port on the computer. Just make sure that you can set the the micro and the converter with the same settings, hand shaking, stop bits, ect...
As for the crystal I would use something like this
http://www.mouser.com/Search/ProductDetail.aspx?qs=CNVyLAqdhH2N35ofopiSog%3d%3d
and use 22pf capacitors.
