Author Topic: Thumbwheel pot with number  (Read 6445 times)
Offline airman00Topic starter
« on: November 27, 2008, 09:55:46 AM »
Can anyone help me out finding a thumbwheel potentiometer with numbers on the top of it
I wanna do something thats gonna look like this:
I want to have three digit number selection - which means three thumbwheel potentiometers with numbers on them.Microcontroller does an A2D on the pot and translates that analog reading into what position the thumbwheel pot is turned to ( aka which number )
« Last Edit: November 27, 2008, 09:56:59 AM by airman00 »
Re: Thumbwheel pot with number
« Reply #1 on: November 27, 2008, 03:59:56 PM »
Why not just use Binary Thumbwheel Switches?
« Reply #2 on: November 27, 2008, 05:12:13 PM »
because I want 999 combinations and dont want that many binary switches :P
« Reply #3 on: November 27, 2008, 07:47:24 PM »
Plain old switches is not what I had in mind - didn't you ever heard of thumbwheel switches?
3 of them is all it takes (and in your case, go for BCD coded output rather than raw binary)
Well, a picture paints a thousand words, or in this case combinations, so here goes...
« Reply #4 on: November 27, 2008, 08:14:03 PM »
Oh I see now what you were referring to.
A thumbwheel pot would be easier to use and interface , but I guess if I cant find a thumbwheel pot I'll use a thumbwheel switch, Thanks for bringing it up.
Anyone know if thumbwheel pots even exist?
Offline Trumpkin
« Reply #5 on: November 27, 2008, 09:35:30 PM »
I did quite a bit of searching for you. I found out at digikey if you search "pot thumbwheel"  P4C1502 through P4D2503 all have numbers on them!
« Last Edit: November 27, 2008, 09:38:40 PM by Trumpkin »
Robots are awesome!
« Reply #6 on: November 27, 2008, 10:06:40 PM »
Thanks but I wanted ones that can be read from the top and not from the side , pictures of which can be found in Soeren's post. They should look exactly like the ones in Soeren's post except be pots and not switches.
