Author Topic: Compass w/Serial Port interface?  (Read 2692 times)
Offline bulkheadTopic starter
« on: November 29, 2008, 11:32:29 PM »
Is there one under $200?  The higher the resolution the better.
If there aren't any (at all or within that price range), I will probably use a dedicated microcontroller to make my own serial port interface.  Any recommendations on the most effective way to send data?  For example, should it send data 20 times per second (start_byte, data1, data2, stop_byte), or should it be polled by the host device (a computer in my case)?
Re: Compass w/Serial Port interface?
« Reply #1 on: November 29, 2008, 11:55:41 PM »
heres what I would do
get a regular ATmega with UART
have it sample the compass sensor
output data onto the serial port at a speed that allows the compass sensor to refresh between readings
TTL to RS232 or TTL to USB connection from microcontroller UART to computer
You only need a start byte , don't need a stop byte.
