Author Topic: connecting photoresistors HELP  (Read 3863 times)
Offline cyclopediatechtilonTopic starter
  • THE MAN KID
« on: November 30, 2008, 03:37:42 AM »
can any1 show me a pic how u connected photoresistors?
the dude. dont mess wit me
Offline szhang
    • szhang.net
Re: connecting photoresistors HELP
« Reply #1 on: November 30, 2008, 03:46:49 AM »
uhm... to do what?
you just use them like a resistor.  read this http://www.societyofrobots.com/schematics_photoresistor.shtml
EDIT:
BTW Admin (from the above page)
Photoresistors (also often called phototransistors...
Really?
« Last Edit: November 30, 2008, 03:50:41 AM by szhang »
  • THE MAN KID
« Reply #2 on: December 01, 2008, 05:34:03 AM »
i donot understand wher 2 connect the photocells in the 50$ robot im using d soldering technique
  • Helpful? 111
    • Webbot stuff
« Reply #3 on: December 01, 2008, 04:51:26 PM »
Assuming you've created the photoresistor as per the tutorial then you will have a 3 pin socket at the end.
Looking at the photovore code it says:
sensor_left=a2dConvert8bit(5);
sensor_right=a2dConvert8bit(4);
So the left photoresistor sockets goes to ADC channel 5
and the right goes to ADC channel 4
Offline HDL_CinC_Dragon
« Reply #4 on: December 01, 2008, 05:23:43 PM »
your photoresistor "eyes" should look like this at the end of them. Then all you have to do is hook them up to one of the sensor headers (depending on whats in the programming. Webbot explained it well)
United States Marine Corps
Infantry
Returns to society: 2014JAN11
  • THE MAN KID
« Reply #5 on: December 02, 2008, 05:02:11 AM »
i m using d soldering technique.
sorry fr being so stupid bt i am a kid
« Reply #6 on: December 02, 2008, 03:00:25 PM »
1) the "soldering technique" will most likely mess you up because it will be MUCH easier to make a few soldering mistakes and short something out. Also, if you connect the wires in the wrong order you could damage something. What I did was I took apart an old computer I had laying around and got some of the wires that hook up to the motherboard jumper pins in the area for plugging in the power switch and reset switch and lights and such and just hooked those wires up to my 'eyes'.
2) Stupidity and being a kid arnt necessarily related. Youre not stupid, your inexperienced. Completely different. No shame in inexperience. We've all been there at one point.
« Last Edit: December 02, 2008, 03:01:38 PM by HDL_CinC_Dragon »
Infantry
« Reply #7 on: December 04, 2008, 06:35:09 AM »
Really?
I see various different definitions online, but to me they all interface the same. For example, a photoresistor is basically a transistor if you consider the light sensitive part the gait. What matters more is the response rate and spectrum sensitivity curve, not what people call them ;D
cyclopediatechtilon, please use proper word spelling. If you misspell words it makes it harder for others 2 undrstnd ur qstion and hardr 4 others 2 search ur qstions. ;)
  • THE MAN KID
« Reply #8 on: December 04, 2008, 06:38:58 AM »
ok i will keep that in mind
