Author Topic: Servo problem PLS HELP  (Read 2705 times)
Offline cyclopediatechtilonTopic starter
  • THE MAN KID
« on: December 15, 2008, 05:57:33 AM »
I was modifying my servo when i came acoss a problem.
The output shaft moves to 360 degrees but when i send the signal to the servo to rotate to 0 degrees, it only moves a little forward
« Last Edit: December 15, 2008, 07:21:35 AM by cyclopediatechtilon »
the dude. dont mess wit me
Offline HDL_CinC_Dragon
Re: Servo problem PLS HELP
« Reply #1 on: December 17, 2008, 11:00:43 PM »
So turn the pot inside the servo until it stops moving.
United States Marine Corps
Infantry
Returns to society: 2014JAN11
  • THE MAN KID
« Reply #2 on: December 18, 2008, 03:39:12 AM »
No i mean that i finished moding my servo.
should the hex of admin work for it to rotate continuously?
« Reply #3 on: December 18, 2008, 02:37:51 PM »
If the servo is already modded and moves when the MCU is sending the zero degree command then chances are you may have modded it improperly by accident. Also, have you checked all the voltages getting to your servo and MCU? Make sure there isnt a power drop into your MCU when both devices are running otherwise that could cause the MCU to put out the wrong signal.
Infantry
  • THE MAN KID
« Reply #4 on: December 19, 2008, 05:18:08 AM »
Another thing,
when i was modding my servo, i rotated the pot head till thegears stopped moving.
but when i shut the battery and put it on again, the gears moved a bit forward and stopped
