Author Topic: Roboduino help for a noob  (Read 4060 times)
Offline geek1Topic starter
« on: December 26, 2008, 07:02:07 AM »
Hi guys, keep in mind I am a total noob so please bear with me. I was just wondering if anyone could tell me how to connect the Roboduino to my PC?
New roboticist and lovin it ;D ;D ;D
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
    • Ro-Bot-X Designs
Re: Roboduino help for a noob
« Reply #1 on: December 26, 2008, 07:35:29 AM »
Easy! Use the USB cable that comes with the kit, download the Arduino software from Arduino website, install the drivers as per the instructions on the Getting Started page, write your sketch in Arduino, download it to the Roboduino! You can open the Serial Monitor to send data and receive (Serial.print) data or you can use Hyperterminal for the same thing. Make sure you select the correct Com port at the same speed you declared it in your sketch (default 9600 bps).
« Reply #2 on: December 26, 2008, 10:13:53 AM »
does that work if I'm programming in straight C?
« Reply #3 on: December 26, 2008, 10:23:41 AM »
if you are programming in straight C you will need to use a hardware programmer to program in the C.
I think the Arduino bootloader might also accept straight C - can someone verify this for me?
« Reply #4 on: December 26, 2008, 10:25:34 AM »
what is a hardware programmer?
« Reply #5 on: December 26, 2008, 10:31:58 AM »
this is a hardware programmer
http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3808
I'm pretty sure you won't need a hardware programmer and could just use the Arduino bootloader. I'll look around online right now. \
EDIT: I even think the Arduino environment can handle regular C, after all the Arduino library is written in C.
I'll get you an answer by Monday.
« Last Edit: December 26, 2008, 10:33:52 AM by airman00 »
« Reply #6 on: December 26, 2008, 12:18:28 PM »
thanks airman00, you have been a great help with all my problems so far, thanks again!!! :D :D :D :D :D :D :D :D :D :D :D
« Last Edit: December 26, 2008, 12:19:19 PM by geek1 »
« Reply #7 on: December 26, 2008, 04:13:19 PM »
hey airman, 1 more quick question, could you tell me how to connect a DC motor to Roboduino?
« Reply #8 on: December 26, 2008, 04:40:16 PM »
you'd need a motor controller
Pololu has some nice ones
Offline Ro-Bot-X
  • Helpful? 25
    • Ro-Bot-X Designs
« Reply #9 on: December 26, 2008, 06:49:07 PM »
Arduino bootloader emulates STK500 protocol to upload the hex file. You can write the code in AVR Studio (plain C) and use AVR Dude to upload the hex file after you make it. Just select STK500 as a programmer in AVR dude.
Offline RoBoTicS
  • Man is a robot with defects
« Reply #10 on: December 31, 2008, 01:23:47 PM »
Awesome thanks Ro-Bot-X
