Author Topic: how to plug in a motor  (Read 4563 times)
Offline geek1Topic starter
« on: December 26, 2008, 03:13:34 PM »
can anyone tell me how to connect a motor to a Roboduino?
New roboticist and lovin it ;D ;D ;D
Offline jamort
Re: how to plug in a motor
« Reply #1 on: December 26, 2008, 03:22:45 PM »
servo or dc?
« Reply #2 on: December 26, 2008, 03:49:24 PM »
DC
Offline HDL_CinC_Dragon
« Reply #3 on: December 26, 2008, 04:36:09 PM »
Do you need to be able to control the motor any more than just turn it on or turn it off? Or do you need to know how many times the motor has rotated and all that good stuff?
United States Marine Corps
Infantry
Returns to society: 2014JAN11
« Reply #4 on: December 26, 2008, 06:48:53 PM »
Never mind guys, I found a continuous rotation servo form solarbotics and will be using that instead.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
    • Ro-Bot-X Designs
« Reply #5 on: December 26, 2008, 07:25:34 PM »
To use a DC motor with the Roboduino or any other microcontroller you need a device that will be able to give the motor the amount of power it needs, that is a lot greater that what the microcontroller can output. This device is called a Motor Driver or H-Bridge. It can be a simple integrated circuit (IC) or can be built using transistors or better MOSFETs. For a beginner it is easyer to use an IC like L293D or SN754410. This IC is a dual H-Bridge, that means it can drive 2 DC motors. If you find it hard to read a schematic and solder the IC on a piece of veroboard, you can buy the Secret Motor Driver that can replace the electronics inside a standard servo motor so you'll have a geared DC motor with a built in motor driver.
Read the PDF file to see the many ways you can use this simple motor driver - inside a servo, on a breadboard, on a geared DC motor and some ways to use the control pins with the microcontroller of your choice.
Here are the links:
http://www.solarbotics.com/products/k_smd/
http://www.solarbotics.com/assets/documentation/kit10.pdf
  • Helpful? 111
    • Webbot stuff
« Reply #6 on: December 26, 2008, 08:29:22 PM »
