Author Topic: Axon Photovore Problem  (Read 4668 times)
Offline JdogTopic starter
« on: January 07, 2009, 03:09:52 PM »
I'm trying to make the Axon photovore. I uploaded this program to my axon: http://www.societyofrobots.com/axon/downloads/Axon_Source_070408.zip
When I turn it on and press the button my right servo rotates perfectly, but my left servo struggles to spin. I took off the top of my servo and I took out the gears to see if it would still struggle to spin because I had assumed I just did a bad job modding the servo, but it still struggled. I then tested it with a different servo and the same problem happened. This leads me to believe that it is a software problem.
Can the timing in the program be off?
Has anyone ever experienced something like this?
Are both of my servos' circuitry broken?
« Last Edit: January 07, 2009, 03:13:09 PM by Jdog »
Offline pomprocker
Re: Axon Photovore Problem
« Reply #1 on: January 07, 2009, 03:54:47 PM »
Swap the header pins that the servos are plugged into, That is if Servo A is plugged into Port/Pin 5 and Servo B is plugged into Port/Pin 6, then plug A into 6 and B into 5. See if the known good servo has this problem. If it does, than it is either a programming problem, or an Axon problem not a servo problem.
« Reply #2 on: January 07, 2009, 04:28:18 PM »
That's what I did when I said that I tested it with a good one.
    • RazorConcepts
« Reply #3 on: January 07, 2009, 05:28:37 PM »
In the code, find where the left servo and right servo are defined, and switch them. Now if the other servo struggles to spin, it is a code problem.
« Reply #4 on: January 08, 2009, 07:10:20 PM »
I switched the servo definitions as Razor Concepts had said, and the same servo span, so I think I'm going to change the port to a completely different port to see if it is a problem with the controller itself.
« Reply #5 on: January 08, 2009, 07:52:51 PM »
Well I figured that out, I don't know what happened but I tried programming it again and it worked so that's good. Now I realized that My wheels are spinning in opposite directions when the robot's trying to go straight. How do I reverse one of the wheels?
    • RazorConcepts
« Reply #6 on: January 08, 2009, 08:32:22 PM »
I think on the Axon, a servo hold (no spin in either way) is a value of 700. So say the value to move foward is 800, but thats the wrong way - so change it to 600 and it should work.
« Reply #7 on: January 08, 2009, 10:30:37 PM »
Ok, I have the  wheels spinning the way they want to now, but when It's supposed to be going straight, the left wheel moves a little bit slower than the right, making a wide curve.
« Reply #8 on: January 09, 2009, 12:21:53 AM »
That just means that the servos aren't modified exactly the same. In the source code you can increase or decrease the servo speed value until its tweaked just right.
« Reply #9 on: January 09, 2009, 08:35:38 PM »
I tried that.
I put the right servo at 602, and the left one at 800, and it still runs slower. (I have the servos plugged into different ports so the code is a little different.)
« Reply #10 on: January 09, 2009, 08:43:08 PM »
You'll have to tweak that value a bit more than that.
It's impossible however to get both wheels *exactly* the same. You'll have to use sensors like a gyro or encoder to match the speeds, but even then there will *always* be some % of error.
« Reply #11 on: January 09, 2009, 08:44:18 PM »
Ok thank you all for your help.
