Author Topic: Programming the Roboduino  (Read 2772 times)
Offline RoBoTicSTopic starter
  • Man is a robot with defects
« on: January 08, 2009, 07:24:56 AM »
The only thing I need is help getting the program started then I should beable to get the rest.  I am trying to program the Roboduino using the Arduino software.  I am trying to program it using a photovore algorithm I am using two servos and two photoresistors (it is similar to the fifty dollar robot)
@Ro-Bot-X  thanks for that guide I have been reading it, it has made me understand some of the stuff to programming,  but like i said I need hellp getting it started
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
    • Ro-Bot-X Designs
Re: Programming the Roboduino
« Reply #1 on: January 08, 2009, 07:33:21 AM »
I'll take a look at the $50 photovore code tonight when I come back from work. Mean while, if you have time, try to write where you plug in the servos (have to be any pair of PWM pins) and where you plug in the sensors (have to be 2 analog pins). Using the samples you have found at the end of the Notebook, try to write a sketch with the definitions and pin setup. We will help you out if you get stuck.
Offline pomprocker
« Reply #2 on: January 08, 2009, 11:19:51 AM »
check the arduino website for free photovore source code. if you find it just make sure you plug the sensors and servos into the correct pins
« Reply #3 on: January 08, 2009, 06:35:41 PM »
sorry I haven't had time yet I just got home from practice and I got a tournament tomorrow and saturday.  So I won't beable to work on it then either.
