Author Topic: Control Axon with PC  (Read 3603 times)
Offline robotcoderTopic starter
    • www.RobotCoder.com (underconstruction)
« on: January 17, 2009, 01:36:02 PM »
I have just purchased an Axon and it will be arriving on Monday. I am trying to figure out if there is a way to send instructions from and old laptop that I have to the Axon, which will then control servos and sensors.  My goal is to use the laptop to run a program that will have to store a lot of information and then send signals to the Axon which will have the code to control the movement of the robot.  Any help would be appreciated.
Thanks, RobotCoder
Re: Control Axon with PC
« Reply #1 on: January 17, 2009, 03:42:05 PM »
Look into UART, which is basically serial
« Reply #2 on: January 18, 2009, 07:39:14 AM »
« Reply #3 on: January 30, 2009, 12:46:28 PM »
The bluetooth controlled lights are really cool, that is what I am wanting to be able to do.  I don't really want to use bluetooth though, I just want to use a usb cable.  Do you have any example code that I can look at that will help me send messages and recieve from the Axon using just a USB cable connection?
« Reply #4 on: January 30, 2009, 08:41:30 PM »
It's *exactly* the same code, not even a slight tweak.
« Reply #5 on: January 31, 2009, 11:50:03 AM »
Ok thanks, I will try using that example then.
