Author Topic: LEDs of different intensity need to be the same brightness  (Read 5364 times)
« on: January 17, 2009, 10:38:36 PM »
Hi all,
I have a need for 8 Red LEDs
I have 8 Red LEDs, but they are different intensities
The dimmer 4 are from Radio Shack:
28mA (max)
Typical Voltage is 2.25, with a maximum voltage of 2.6V
Typical MCD is 5.0
http://www.radioshack.com/product/index.jsp?productId=2062552&tab=summary
The brighter 4 are from Sparkfun.com
I have no tech specs on them
http://www.sparkfun.com/commerce/product_info.php?products_id=533
I would like to make them around the same brightness if possible.
The voltage supplied will be either 2.4(if using rechargeable batteries) and 3v (alkaline - i expect this most of the time)
So what series resistor should I use with the bright one, and what resistor with the dim one to get them to equal in brightness
Re: LEDs of different intensity need to be the same brightness
« Reply #1 on: January 17, 2009, 11:08:28 PM »
First off... You should get 8 new LED's of the same type!
Mixing different LED's where you want the same look and feel is a bad idea and buying 8 LED's won't ruin you ($1.49 is hilarious though and 50 cents are still way too expensive).
LED's 50 Bright Red 3mm 1.9-2.5 Volts 30mA for $5.99
http://cgi.ebay.com/LEDs-50-Bright-Red-3mm-1-9-2-5-Volts-30mA_W0QQitemZ300259652126QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item300259652126&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A4%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A200
1000 red diffused 3 mm LED's for $10.99
http://www.besthongkong.com/product_info.php?manufacturers_id=&products_id=30
A rating in mcd (millicandela) is worth nada without the angle of half intensity. -Theoretically, you could make any LED give eg. 100,000 mcd, by simply reducing their angle of half intensity.
To get a comparable measure, you need both the mcd and the angle to convert to lm (Lumen), then use the lm to see how bright any LED actually is.
To get an understanding of the concept, use a magnifying glass and focus/defocus the image of the sun - the smaller the spot (i.e. angle), the brighter it will be.
« Reply #2 on: January 17, 2009, 11:13:59 PM »
Yeah radio shack and sparkfun are both too expensive for components.
This is for a hand held POV, so you're right, I should get 8 matching LEDs
I think I will drive up to this bigger electronics shop that has a better selection.
What LED and resistor specs to you recommend to get as bright as possible with 3v supply, 2v fwd drop, and 20mA?
Offline HDL_CinC_Dragon
« Reply #3 on: January 17, 2009, 11:33:42 PM »
depends on the LED really. Typically the LEDs that take the most voltage will be the brightest. Since the LED packages typically give you the voltage and current rating for the LED you can very easily calculate the resistor value.
United States Marine Corps
Infantry
Returns to society: 2014JAN11
« Reply #4 on: January 18, 2009, 04:55:05 PM »
Finding the resistor is purely Ohms Law, so I won't insult you by giving you an answer on that one ;)
The LED should of course be the one fitting the purpose and having the highest intensity (in lm).
You need to decide which angle will suit your purpose best and then go from there.
To get a higher intensity, just up the current a bit, you don't wanna play with a POV toy for 100,000 hours anyway. Don't go much above around 50mA for one nominated for 20mA though, unless you're willing to sacrifice a few experimenting.
Those little key ring lamps with either 2 of CR2032 or 3 to 4 of AG13 or similar relies on the fact that you won't be using it for more than perhaps 10 to 100 hours during its lifetime, so they are heavily overdriven to get useable brightness.
« Reply #5 on: January 28, 2009, 01:03:10 AM »
arrrrrrrg
so i have 3mm red leds from radio shack, sparkfun, and my local electronics shop. none of em really came with specs, but the sparkfun ones are the best!   what are theyyyyy   they don't have the specs on them either cause i emailed them    :-\
« Reply #6 on: January 28, 2009, 04:56:38 PM »
I would assume 3v at 20mA for the LEDs... buuuut not really sure what your really asking here lol
Infantry
« Reply #7 on: January 28, 2009, 04:58:10 PM »
I want more of the ones that sparkfun sells, but I want to get them from somewhere cheaper and not pay $0.50 each for them :\
« Reply #8 on: January 28, 2009, 05:03:53 PM »
well what do you mean by theyre the best? Do you mean you ran the same current and voltage through them and the sparkfun ones were brighter?
Infantry
« Reply #9 on: January 28, 2009, 05:07:00 PM »
Yeah I breadboarded all my different red LEDs, and figured out which resistor worked best 47ohm gave me 25mA current with a 3v supply. Then i did a persistance of vision test my waving the breadboard around in the dark LOL
the sparkfun ones were the brightest, diffused, and had the best viewing angle.
The second best were the NTE super bright deep red 3mm led, but its not diffused.
I think i might try sandpapering one of them tonight and see if that makes it work as well as the sparkfun LED for the purpose of a POV toy.
« Reply #10 on: January 28, 2009, 05:13:34 PM »
You gave each LED its own resistor right? Cuz if you just put em all in parallel with just one resistor supplying them all then they werent all getting the same power
Infantry
« Reply #11 on: January 28, 2009, 05:14:48 PM »
of course they all have their own resistor
« Reply #12 on: January 28, 2009, 05:24:35 PM »
Side topic: But if they are exactly the same specs and same LED , it would be fine, correct?
« Reply #13 on: January 28, 2009, 05:27:01 PM »
airman: Consult the wizard
http://led.linear1.org/led.wiz
« Reply #14 on: January 28, 2009, 10:45:41 PM »
no, if theyre in parallel they all need their own resistor. As admin had pointed out to me in a post somewhere on here, the LEDs will have extremely tiny internal resistance differences but just enough that if 2 LEDs were in parallel with the same source resistor then one LED could be taking 10 times the current as the other one. When in series it does matter
Infantry
« Reply #15 on: January 28, 2009, 11:43:53 PM »
problem solved, i filed down the epoxy on the nte super brights with an emory board
« Reply #16 on: January 29, 2009, 02:59:27 PM »
hahaha emory boards are freakin great, I have one on my workbench as well :)
Infantry
