Author Topic: equivalent caps?  (Read 2704 times)
equivalent caps?
« on: January 18, 2009, 03:56:52 AM »
This is a very n00b question and I wish I could delete this post after getting the answer but,
I have a schematic that calls for a 100uF 10v cap, and all I have is a 100uF 35v cap. That just means that the cap can handle up to 35volts versus 10 volts correct? with this have and adverse effects on the circuit?
Offline want2learn
Re: equivalent caps?
« Reply #1 on: January 18, 2009, 04:36:02 AM »
Yes the voltage rating is just how much the capacitor can handle.
In most (99.99%) cases it doesn't matter, Just never use a cap with a lower voltage rating.
The only cases where I Know it matters is when the circuit needs a low ESR cap.
Am I, or the others crazy?
Offline HDL_CinC_Dragon
« Reply #2 on: January 18, 2009, 04:43:40 AM »
a general rule of thumb is always use a cap rated for twice the voltage you expect to ever reach it
United States Marine Corps
Infantry
Returns to society: 2014JAN11
« Reply #3 on: January 18, 2009, 04:39:48 PM »
If you need low ESR, a higher voltage rating is a good thing.
Offline krich
« Reply #4 on: January 18, 2009, 05:56:04 PM »
Another downside to using a higher voltage cap when it's not necessary is the cap is usually bigger.
