Author Topic: Can someone check my eagle schematic for errors?  (Read 5149 times)
« on: January 21, 2009, 12:39:45 AM »
attached
Its a USB to RS232 Breakout board. It can be found in the examples in the ft232rl datasheet
« Last Edit: January 21, 2009, 12:47:31 AM by pomprocker »
Re: Can someone check my eagle schematic for errors?
« Reply #1 on: January 21, 2009, 04:02:56 AM »
Please post the Eagle files (.sch and .brd) and I will look it over. Some errors won't show on a picture, so I'll wait for the design files.
Offline bukowski
« Reply #2 on: January 21, 2009, 11:16:04 AM »
Why doesnt anybody use bus lines? They only take a couple of more minutes, but they do clean up a schematic.
« Reply #3 on: January 21, 2009, 11:54:07 AM »
I'll post the design files tonight when I get home.
Bus lines....I'm very new to eagle...only used it a couple days now.
Offline TrickyNekro
  • Hardware and Firmware Designer
    • The Hellinic Robots Portal
« Reply #4 on: January 21, 2009, 12:05:11 PM »
Bus lines are mainly for parallel signals....
They won't do here.... :P
Post the libs... and we can get something!!! 8)
« Reply #5 on: January 22, 2009, 01:10:37 AM »
posted...
Offline TrickyNekro
« Reply #6 on: January 22, 2009, 04:40:00 AM »
Check this man...
There are some corrections...
I don't know if your schematic is correct as far as the components go...
But I did some "CAD" corrections 8)
« Reply #7 on: January 22, 2009, 11:05:57 AM »
Thanks man, I needed some help cleaning it up ;)
As far as the circuit being correct, well i'll just have to test it on a breadboard before i send off the pcb
« Reply #8 on: January 22, 2009, 03:44:04 PM »
Here's my take on what you have wired up so far.
Here's some advice, that could help you along...
Be carefull with your junctions (green dots on wires) and don't just sprinkle them on - if you see a junction where none should be, you might have more than one wire.
Place capacitors in a logical manner, to show where they belong (eg. close to the positive line when used as decoupling).
You used Vcc and Gnd. In digital circuits, you should use Vdd for positive and Vss for negative line. In analog circuits, it's Vcc and Vee respectively.
Gnd is for ground lines.
« Reply #9 on: January 22, 2009, 09:31:23 PM »
Wow thats really cleaned up.
I dunno what to call it but for gnd i need 0v, and voltage is 5v.
The only reason i labeled it vss on the jumper is because that is what the pin on the BS2 is called
Oh and one more thing....The MAX213 has vcc and gnd pins, 10 and 11, but they seem to be hidden....how does that work?
« Last Edit: January 22, 2009, 09:32:11 PM by pomprocker »
