Author Topic: CAN I USE THIS SERVO FOR THE $50 ROBOT  (Read 3523 times)
Offline strydomTopic starter
« on: January 25, 2009, 08:25:11 AM »
hi i have a problem that i think is quit seereos i live in britan and i am making the $50 robot but can not find the servo that u are suposed to use for the $50 robot for a desent price so i thought i would get a different one but wasent sure if it would be ok to use and if i hade to change the programing and what i would have to change the programing to.
here are the specs on the servo i whant to get but it dident say what modole it was like sh-311, it just said hitec servo.
This servo be used in any standard servo application such as radio control, but it can also be used in its own right as an accurate and powerful actuation unit for robotics and remotely controlled movements.
Weight: 34g
Torque: 56.9 oz-in (at 6V)
Speed: 0.16 sec/60 degrees (at 6V)
Size: 55 x 20 x 45mm
Connections
Negative - brown
Positive - red
Signal - orange
and here is the adrees for it.
http://www.mutr.co.uk/product_info.php?cPath=13_530&products_id=1009437
so is it ok for me to use this servo and is it better or wors than the servo the guy whants me to use.
plz help me i am a biginer in robotics and dont know what is ok to use and not.
Re: CAN I USE THIS SERVO FOR THE $50 ROBOT
« Reply #1 on: January 25, 2009, 10:25:54 AM »
people i realy need your help plz tell me if it is ok or not plz plz ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :(
« Reply #2 on: January 25, 2009, 10:26:50 AM »
sure its good enough
« Reply #3 on: January 25, 2009, 10:29:54 AM »
thanks for reeplyin but do i need to change the programing
« Last Edit: January 25, 2009, 10:31:36 AM by strydom »
« Reply #4 on: January 25, 2009, 10:40:49 AM »
no
please stop emailing me btw.... :-\
« Reply #5 on: January 25, 2009, 10:52:56 AM »
lol sory i just realy needed to know thanks for your help
Offline HDL_CinC_Dragon
« Reply #6 on: January 25, 2009, 12:19:06 PM »
Expect to wait even a couple days before getting a reply to your posts, Strydom.
As long as its an analog and not a digital servo you can use it. The modification to make it continuously rotate should be pretty much the same as well.
That servo you posted a link to is actually a little bit stronger than the HS-311 which should make you happy. Just remember to get 2 of them to make your drive system :)
United States Marine Corps
Infantry
Returns to society: 2014JAN11
« Reply #7 on: January 26, 2009, 12:33:34 PM »
ok thanks and yes that did make me happey :D
Offline MaltiK
« Reply #8 on: January 26, 2009, 05:00:56 PM »
All analog servos are the same, and digitals are mad expensive so dont worry 'slong as you have three cords, red black and white or yellow
Warranty
« Reply #9 on: January 27, 2009, 10:47:43 AM »
yes thanx but this servo has red/brown and orange wires
but i think that still ok isent it.
