Author Topic: DC motors with Axon  (Read 6350 times)
Offline HanoushTopic starter
DC motors with Axon
« on: February 07, 2009, 12:32:42 PM »
I am building a Quadcopter and I was wondering if I can connect my Axon directly to the "DC motors" using "PWM" and without using "H-bridge" or "motor controller" ??
can this be done ?
    • RazorConcepts
Re: DC motors with Axon
« Reply #1 on: February 07, 2009, 12:37:45 PM »
Most likely not, since the pins can only put out like 20-40ma, and your motors will most likely draw more power than that. One option is to just use a brushed ESC for airplanes which you can connect directly to the Axon.
Offline horo333
« Reply #2 on: February 07, 2009, 12:39:35 PM »
yes, i use DC motors for my robot, you just plug them in, and...use the breadboard, not the pc com...there is no solderin'
like robots, not u
Offline TrickyNekro
  • Hardware and Firmware Designer
    • The Hellinic Robots Portal
« Reply #3 on: February 07, 2009, 12:57:03 PM »
NO THE HELL NO!!!! PLEASE!!!!
You are gonna burn the pin for sure.... when it is written that these pins can output 20mA means that if there is a larger
current draw then.... good bye happiness....
And it's sure that a DC motor will draw more than 20mA due to very low internal resistance....
Use an H-bridge.... No question about it....
Are these things RC motors???
My speed 400 with a fan draws about 11A from the supply!!!! So you are going to need Mosfets.... if so...
Offline horo333
« Reply #4 on: February 08, 2009, 07:23:32 AM »
ok, can you tell me where to buy the H-bridge, or motor driver, and...what's better ? ;D ;D ;D
like robots, not u
  • Helpful? 111
    • Webbot stuff
« Reply #5 on: February 08, 2009, 12:11:42 PM »
You can get them from lots of places. Google.
www.DimensionEngineering.com, solarbotics amonst others. Or you can make your own. But before you start - you need to know how much current your motors need.
Offline horo333
« Reply #6 on: February 08, 2009, 01:01:28 PM »
like robots, not u
Offline horo333
« Reply #7 on: February 08, 2009, 01:02:58 PM »
i don't see where to put my motor wires(there's only two +, -)
like robots, not u
  • Helpful? 111
    • Webbot stuff
« Reply #8 on: February 08, 2009, 01:10:09 PM »
Its NOT a motor controller - its a power supply !!!
That website has various motor controllers for 5 amps and greater:
eg http://www.dimensionengineering.com/Sabertooth2X5.htm
But - and I repeat what I said earlier. You NEED TO KNOW HOW MUCH CURRENT your motors will need. It could be anything from a few 100mA up to 10's of Amps.
So a cheaper motor controller that can supply less power is : http://www.solarbotics.com/products/k_cmd/
Offline horo333
« Reply #9 on: February 08, 2009, 01:40:05 PM »
im buyin' new servos, bye-bye waries ;D ;D ;D
like robots, not u
« Reply #10 on: February 09, 2009, 03:13:52 PM »
Thanks a lot guys, I am thinking to put a relay before my motor & send PWM signal to it.
« Reply #11 on: February 09, 2009, 09:47:03 PM »
A relay will require like 200mA . . . still won't work.
Since you are making a quadrotor, you don't need a full motor driver. Your motors will only spin in one direction unless you want to do crazy tricks with it.
All you need is a single NPN MOSFET per motor. Attach the Axon PWM pin to gate, attach the source pin to ground, and the drain pin to your motor. The other wire on your motor attaches to battery power.
Make sure the MOSFET you get is rated for the voltage/current your motor uses. You can buy one at mouser.com for about ~$3 each. Solder it all onto a protoboard.
You can find motor drivers and everything else here:
http://www.societyofrobots.com/robot_parts_list.shtml
« Reply #12 on: February 10, 2009, 04:36:45 AM »
I was thinking about buying this :
http://www.robotshop.ca/solarbotics-l298-motor-driver-kit.html
I will get one for every 2 motors,so that can save me some weight.
« Reply #13 on: February 10, 2009, 05:03:44 AM »
That will work . . . but all you need is just a single MOSFET per motor . . . it'll be the size, shape, and weight of a voltage regulator . . .
« Reply #14 on: February 10, 2009, 05:30:28 AM »
Yea But I think I will need a Breadboard for it.
« Reply #15 on: February 10, 2009, 11:37:53 AM »
Nah no breadboard, just get the 'PC board' such as for my $50 Robot:
http://www.societyofrobots.com/step_by_step_robot_step3B.shtml
You can then saw off parts of it to reduce size/weight.
