Author Topic: computer mouse wiring  (Read 5941 times)
Offline frodoTopic starter
  • BOW DOWN TO MY MIGHTY STARE!!
« on: February 09, 2009, 02:39:53 PM »
hi, i took apart a computer mouse and ripped out the wires before thinking. now i don't know which wire goes where. it still has the computer connector on the other end so i was wondering whether you guys know of anything i can do with the wires (please don't say chuck them in the bin).
OMG!!!! I AM SUPREME ROBOT!!!
Check out my Web
Offline HDL_CinC_Dragon
Re: computer mouse wiring
« Reply #1 on: February 09, 2009, 03:38:52 PM »
Do you by any chance have a model number for the mouse? That might help get some answers
United States Marine Corps
Infantry
Returns to society: 2014JAN11
« Reply #2 on: February 09, 2009, 03:40:26 PM »
i don't actually because the case of it went in the bin and its from about 15 years ago :(
Check out my Web
  • Helpful? 111
    • Webbot stuff
« Reply #3 on: February 09, 2009, 06:38:15 PM »
@Frodo - are you asking 'how do I put the mouse back together?' or 'what can I use wires for?'  ;D
Offline jka
« Reply #4 on: February 10, 2009, 03:13:25 AM »
If you are asking is you can use the connector and want to know which pin on the connector goes to which wire, the use a multimeter to check each pin with each wire. If you don't have a multimeter, create some small circuit with a lamp or LED and use that.
« Reply #5 on: February 10, 2009, 11:45:51 AM »
@ jka
how will a lamp or an LED work? it will only test connectivity, won't it?
Check out my Web
Offline chelmi
    • Current projects
« Reply #6 on: February 10, 2009, 01:38:18 PM »
@ jka
What do you want exactly? Use the wires? Use the connectors?
« Reply #7 on: February 10, 2009, 03:06:24 PM »
Yeah.
You could use the wires to create a sort of quick disconnect thing on one of your robots if you get a female port to plug the connector into. Solder the port onto your robot board and hook the other wires up to a Serial jack or something.
Infantry
« Reply #8 on: February 10, 2009, 03:32:12 PM »
you lost me with that in the first line Dragon, and i haven't actually built a robot.
Check out my Web
