Author Topic: Axon Power Supply  (Read 4283 times)
Offline hendrachubbyTopic starter
    • My-Blog
Axon Power Supply
« on: February 11, 2009, 07:10:52 PM »
Can i use 6 Volt adaptor for Axon Power Supply ?
Offline MaltiK
Re: Axon Power Supply
« Reply #1 on: February 11, 2009, 07:15:02 PM »
Absolute minimum required voltage is 5.35V, while the recommended battery voltage is 6V to 7.2V. Maximum voltage at 20V, however most servos cannot handle above 7.2V before being damaged.
Warranty
Offline Jdog
« Reply #2 on: February 11, 2009, 08:04:44 PM »
Yes but make sure it's actually putting out 6 volts because most adaptors put out a few volts above what they say they do. If it is doing that you could put a 6 volt regulator in between the power supply and the axon.
