Author Topic: I need some servo help.  (Read 2725 times)
Offline galannthegreatTopic starter
« on: February 12, 2009, 08:57:02 PM »
I've got my servo panning back and forth, but it's not enough, I change for a longer delay and it doesn't change anything. What am I doing wrong?
#include "16f877a.h"
#use delay(clock=20000000)
#fuses HS
void main()
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   while(1)
   output_high(PIN_D0);
   delay_us(500);
   output_low(PIN_D0);
   delay_ms(1000);
   delay_us(1500);
   output_low(PIN_D0);
   delay_ms(1000);
   delay_us(2500);
   output_low(PIN_D0);
   delay_ms(1000);
   delay_us(1500);
   output_low(PIN_D0);
   delay_ms(1000);
PS I am using a PIC 16F877a and I'm writing the code in CCS C.
Kurt
Re: I need some servo help.
« Reply #1 on: February 12, 2009, 09:14:11 PM »
and wow, I must not be having a good day because this topic is in the wrong category, sorry for any troubles.
Kurt
Offline Hawaii00000
« Reply #2 on: February 13, 2009, 08:12:18 PM »
If it doesn't rotate far enough it might be just the servo. How many degrees is it supposed to rotate?
-Paul Dirac
Its Hawaii Five-O. Get it?
« Reply #3 on: February 15, 2009, 09:05:38 PM »
Can you clarify exactly what it is actually doing, and what you want it to specifically do?
