Author Topic: I need some help to juat test my motors.  (Read 3733 times)
Offline galannthegreatTopic starter
« on: February 12, 2009, 10:24:00 PM »
I need some help with testing my bot, I use the code:
output_high(PIN_D5);
   output_low(PIN_D4);
   output_high(PIN_D6);
   output_low(PIN_D7);
Basically pins D4 and D5 controls one motor, and D6 and D7 the other, am I missing anything or is this correct?
Kurt
Re: I need some help to juat test my motors.
« Reply #1 on: February 12, 2009, 10:25:03 PM »
What is your electronic setup?
You cant just connect a DC motor to a microcontroller pin
« Reply #2 on: February 12, 2009, 10:26:43 PM »
Sorry, they are connected to a SN754410 Driver
Kurt
Re: I need some help to just test my motors.
« Reply #3 on: February 12, 2009, 10:36:11 PM »
I know my wiring is correct, I just know I'm wrong in the programming end.
Kurt
    • RazorConcepts
« Reply #4 on: February 12, 2009, 11:04:46 PM »
After you set the pins, try an infinte while loop that does nothing.
