Author Topic: Ping))) and Axon  (Read 2850 times)
Offline ResilientTopic starter
Ping))) and Axon
« on: February 15, 2009, 02:31:42 AM »
I got another question.  Ill run out soon.  I am almost out of sensors :P
Looking through the code it looks like you are supposed to plug the Ping))) into the A3 position but, I thought it was always a good idea to plug a sensor like the Ping))) which uses 5v into the 5v regulated bus?
Or do I have to pull the power off the 5v bus but plug the singal into the A3 socket because its digital?
J
Offline pomprocker
Re: Ping))) and Axon
« Reply #1 on: February 15, 2009, 03:00:56 AM »
I do not own an Axon (yet) but I originally wrote that code for the $50 robot board, and I just plugged it into an ADC pin.
Offline Tomas
« Reply #2 on: February 15, 2009, 03:34:57 AM »
Did you have any problems using port A3?
« Reply #3 on: February 15, 2009, 05:38:11 AM »
You should use regulated 5V for the Ping))). You can still use pin A3 for I/O, but power should be taken from the ADC power bus line (the 5V regulated line).
