Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
What Razor Concepts says probably works for all sane servos. Unfortunately my servos are not sane and they remamber the last command I issued, for ever. If you're blessed with one of those insane servos then not sending the servo command will not make them stop: you'll need to send the "center servo" command first (ie: a 1.5 ms pulse)!
The only problem with that is usually, the servo is not centered perfectly, and then it's almost impossible to center like that. Unfortunately I have an insane servo and I don't know how to stop it, because I don't want to use another output to stop it.
Add a mosfet between a output pin on the Axon and the power pin on the servo, then just turn it off
