Author Topic: Need Simple Butler Bot help  (Read 3518 times)
Offline robotnerdTopic starter
« on: March 02, 2009, 04:29:23 PM »
Hola people i was wondering if it is possible to make a robot come to you on romote command while avoiding obsticles if so how
plz dont tell me to try the $50 robot i hae already done it
if you can that would be awesome thnx so much. attached is the most basic picture of what  i would like it to look like i have the chasis built but its the actual serving that i am stumped at.
« Last Edit: March 02, 2009, 04:39:44 PM by robotnerd »
Offline Jdog
Re: Need Simple Butler Bot help
« Reply #1 on: March 02, 2009, 08:33:18 PM »
The only way I could think of is having some transmitter(radio or whatever else you could think of not infrared) as a remote and having 3 recievers placed on different spots of the robot. Then whichever reciever recieves a stronger signal is the direction it's coming from. Now for the object avoidance you could either have a map pre-programmed into the robot or you could have it do active mapping. I dont know much about it but look into maze-solving robots. This would be a very difficult robot and unless you have the map pre-programmed into the memory, it would be pretty slow service because it would keep looking around in a random manner until it found a good path.
« Reply #2 on: March 03, 2009, 06:22:53 PM »
well this is for some extra credit in school and i don't think i could download the entire school's map and plus i was thinking about taking it outside of school. is it possible to use a sonar sensor or a sharp Ir ?
Offline Jdog
« Reply #3 on: March 03, 2009, 08:33:44 PM »
I'm not sure if you could, I'm not experienced in mapping. You might be able to.
Offline superchiku
  • cooll
« Reply #4 on: March 03, 2009, 09:31:21 PM »
see the member tutorials on butler robot...
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline Joesavage1
    • Dev-HQ - Learn C++, Visual Basic, HTML and More!
« Reply #5 on: March 04, 2009, 10:11:58 AM »
if youve already built the $50 robot, maybe you could work on an expansion for it that could be a butler bot (im sure ill try when im done)
Offline Canabots
  • Helpful? 6
    • Salmigondis Tech
« Reply #6 on: March 04, 2009, 08:30:24 PM »
www.saltech.wordpress.com
