Author Topic: Question concerning powering circuit  (Read 2430 times)
Offline davie_gravyTopic starter
« on: March 06, 2009, 03:28:51 PM »
So I've just completed wiring up the brain.  I've realized I have an issue with the circuit and some of the welds.  My question is how will I know first hand that the circuit is wired correctly aside from actually having to connect it up to the computer.  Will the LED light up if the circuit is wired correctly with the battery plugged in?  Is there an easy way for me to tell that the circuit is wired correctly?  Any help is greatly appreciated.  Thanks!
Offline dellagd
    • Exodus Rocketry
Re: Question concerning powering circuit
« Reply #1 on: March 06, 2009, 03:53:57 PM »
first of all, by brain do you mean microprocessor and weld as soldering joint?
Are you working on the $50 robot?
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
Offline Trumpkin
« Reply #2 on: March 06, 2009, 05:13:18 PM »
If you are building the $50 robot the LED will not light if you plug the battery in. It only lights when it is programmed.
Robots are awesome!
« Reply #3 on: March 07, 2009, 04:43:15 AM »
Is there any easy way to tell if the circuit is wired correctly aside from having to hook it up and try to write the code to it?
Offline dellagd
    • Exodus Rocketry
« Reply #4 on: March 07, 2009, 07:33:07 AM »
you could do some continuity tests and match it up w/ the images Admin has (step 3B of $50 robot)
I Won!
