Beginners: please read this post and this post before posting to the forum.
5) Next we need to center the servo. Do this by plugging it in to your controller and send the signal required for it to go to 0 degrees. You should probably see the gears rotating without stopping. Now rotate the pot head (no, not that type of pot head) so that the gears stop rotating. It will probably be very sensitive so take your time. It is very important for this to be perfect. Get some superglue and glue the pot head to make sure it remains in place.
#include <Servo.h> Servo myservo; // create servo object to control a servo // a maximum of eight servo objects can be created int pos = 0; // variable to store the servo position void setup() { myservo.attach(9); // attaches the servo on pin 9 to the servo object } void loop() { for(pos = 0; pos < 0; pos += 1) // goes from 0 degrees to 180 degrees { // in steps of 1 degree myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } }
Note that 0 in the arduino program does not center the servo, 0 means it is all the way to the left or right.
