Author Topic: problem with 5v regulator  (Read 3331 times)
Offline ptumikTopic starter
« on: March 19, 2009, 01:25:58 AM »
it looks like my 5v regulator from $50 robots doesn't work.
I have connected my battery to it, and I have uncontrolled voltage to my servos (which is fine) and zero volt to my circuit.
How can I check if it's working correctly?
Re: problem with 5v regulator
« Reply #1 on: March 19, 2009, 04:39:12 AM »
do you have it connected the right way around? and are you using a common gnd?
Offline Private Reid
  • I love apples ... Yum !!!
« Reply #2 on: March 19, 2009, 05:42:52 AM »
I had the same problem
Check your connections to the regulator, if it's getting unusually hot you've got it wrong.
Offline dellagd
    • Exodus Rocketry
« Reply #3 on: March 19, 2009, 06:15:18 AM »
make sure you're plugging in the battetries the right way
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
« Reply #4 on: March 19, 2009, 01:08:13 PM »
I'm pretty much sure that I have connected it the right way, but will double check today.
Also, I'm using common ground.
Regulator isn't hot at all.
And I have connected the battery correctly, I double checked that.
Will give it a try tonight, and if unsuccessful will post a photo.
Thanks for helping!
Offline pomprocker
« Reply #5 on: March 19, 2009, 05:04:42 PM »
use a multimeter on the legs of the regulator
Offline offy
« Reply #6 on: March 19, 2009, 06:11:07 PM »
I had a problem of the regulator getting very hot. I checked all my connections, I mean ALL of them, every wire, capacitor and everything and I finally got it working, but never used it, didn't have all the features I wanted.
Offline dellagd
    • Exodus Rocketry
« Reply #7 on: March 19, 2009, 06:11:28 PM »
also, if the problem persists, do some continuity tests to make sure all of the soldering is good.
I Won!
Offline dellagd
    • Exodus Rocketry
« Reply #8 on: March 19, 2009, 06:16:10 PM »
to offy:
how did you fix the problem?
I Won!
« Reply #9 on: March 19, 2009, 09:01:51 PM »
false alarm.  :-[
double checked right now - all is working fine.
except that my diode stopped working. :) but that is easier to fix.
