Author Topic: Is there anyway to hack a dead iPod's LCD to use for a display?  (Read 7328 times)
Offline galannthegreatTopic starter
I have a dead iPod with the LCD still intact and I want to eventually use it as a display on the next robot I am planning with a buddy, any ideas on how I could go about this?
Actually about the datasheet thing, I just asked a buddy of mine and he said he found one that outlines the LCD of my ol' 5th gen, thanks for that suggestion. I've also got quite a few cell phone LCD's in which I've figured out the connections.
« Last Edit: March 23, 2009, 09:36:12 AM by galannthegreat »
Kurt
Offline TrickyNekro
  • Hardware and Firmware Designer
    • The Hellinic Robots Portal
Re: Is there anyway to hack a dead iPod's LCD to use for a display?
« Reply #1 on: March 23, 2009, 04:01:57 AM »
If you can find the datasheet of the controller then, I guess that ok...
But companies like Apple, Sony Ericsson..... don't easily give out their datasheets,
even if the product is long discontinued.....
It's all about the datasheet....
BTW, you can also get the LiPo battery if you know how to use it and charge it!!!
Else.... fireworks... :-p
« Reply #2 on: March 23, 2009, 04:03:51 AM »
are li-po's the ones that go boom if exposed to water?
    • RazorConcepts
« Reply #3 on: March 23, 2009, 06:02:33 AM »
Or if you puncture them, discharge them too fast, or overcharge them. People have lost their homes due to lipos so they aren't to be messed around with.
« Reply #4 on: March 23, 2009, 09:34:00 AM »
I know how to work with LiPo's, and yes the dangers are extreme, so if possible I try to use LiIon.
Kurt
« Reply #5 on: March 23, 2009, 12:59:09 PM »
yeah, at cadets we got a 25min lecture about how not to do anything like that to those batteries in our radios or it would most definitely take out our whole squadron. i still dont know why they still use those batteries? do they last long? small?
« Reply #6 on: March 23, 2009, 02:03:39 PM »
They are very cheap to manufacture, so I guess that would be a good reason.
Kurt
Offline want2learn
« Reply #7 on: March 23, 2009, 02:11:06 PM »
Li-po's are relatively cheap to manufacture and have a high capacity to weight ratio which means more punch for your pound
Am I, or the others crazy?
« Reply #8 on: March 23, 2009, 02:15:12 PM »
im still scared of using them :P
Offline want2learn
« Reply #9 on: March 23, 2009, 02:58:26 PM »
properly cared for li-po's are the best investment battery wise in my opnion
« Reply #10 on: March 23, 2009, 03:12:01 PM »
i do agree but i have heard really bad stories from my corpral and a guy i know in the raeme of people dying of some kind of acid being in their lungs from these batteries exploding. but i will look into them and use some kind of protection circuit like trickys.
« Reply #11 on: March 24, 2009, 08:49:56 PM »
those are usually what I call "extreme" cases of people doing dumb stuff, if you use it under normal situations there should not be a problem
Kurt
« Reply #12 on: April 07, 2009, 10:04:11 PM »
I found a site where a guy has hacked the screen and got it work on an MCU, check it out if you're interested in doing this yourself:
http://www.electricstuff.co.uk/ipodlcd.html
I hope this will be helpful to some!!! ;D
« Last Edit: April 07, 2009, 10:15:01 PM by galannthegreat »
Kurt
« Reply #13 on: April 07, 2009, 10:29:08 PM »
and now I seem to have found the connector for this one:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=HFK132CT-ND
 EDIT
don't mind that link, it seems to be the wrong connector, if anyone can find the connector w/o having to order mass amounts of it, it would be much appreciated to send the info my way.
Thanks, Kurt.
« Last Edit: April 07, 2009, 10:37:49 PM by galannthegreat »
Kurt
Offline TrickyNekro
« Reply #14 on: April 08, 2009, 05:06:23 AM »
My lab has an Logic Analyzer that can be of great help!!!
Generally, have a logic analyzer and a good scope and you can do anything.... Anything!!!
I get to look for a connector.... How many pins do you read?
« Reply #15 on: April 08, 2009, 10:19:29 AM »
The connector is a 32pin, 0.3mm pitch connector, the manufacturer is DDK, but they require you to buy lots and I only need 2 or 3.
Kurt
