Author Topic: Data that persists over a power off cycle  (Read 4157 times)
Offline ResilientTopic starter
« on: March 22, 2009, 10:21:45 PM »
With the axon is it possible to have gathered data last over a power off power on cycle?
For example, if I want to remember a path for a maze that I ran, is there a way to store that somewhere so I can power off and still have it there when I power on?
Or if I want to calibrate for lighting conditions between runs of a firefighting robot?
Offline pomprocker
Re: Data that persists over a power off cycle
« Reply #1 on: March 22, 2009, 11:18:33 PM »
The same kind of memory your programming is stored on...EEPROM
« Reply #2 on: March 23, 2009, 01:01:20 AM »
I guess I should rephrase.
How would I do it?
Is it possible to dedicate a portion of the memory that you can write to?  For example, if I wanted to store a two dimensional array that represented what the robot knew about a maze, how would I do that?
Or a simpler case, how would I write a single int that could be used as the baseline light level for a series of runs?
Are there any functions in the AVR library that support this?
    • RazorConcepts
« Reply #3 on: March 23, 2009, 03:51:04 AM »
See link in my sig, basic EEPROM tutorial  ;D
« Reply #4 on: March 23, 2009, 06:08:27 PM »
WIN!  ;D
Offline pomprocker
« Reply #5 on: March 23, 2009, 09:15:41 PM »
Is that for internal or external eeprom?
    • RazorConcepts
« Reply #6 on: March 23, 2009, 09:38:10 PM »
Internal EEPROM.
Offline pomprocker
« Reply #7 on: March 23, 2009, 09:47:54 PM »
maybe you could add how to hook up external eeprom via spi or something
« Reply #8 on: March 23, 2009, 10:50:02 PM »
Just in case anyone changes their sig . . .
http://www.societyofrobots.com/member_tutorials/node/309
