Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
The directions say to keep the charger far away from the battery as possible, so I'm hesitant to mount the charger on my robot.
Once again, the apparatus is just two ring terminals (that connect to the battery), some wire with a fuse box mounted with a 15Amp fuse, and a plastic wire connector that can be plugged directly to the charger mechanism. So, what I could do is keep those two ring terminals attached to the battery permanently. Whenever I want to charge the battery, I just plug the plastic wire connector into the charger and apply power to the charger. That way I wouldn't have to take off the duct tape and put on the alligator clips every time I want to charge the battery.
By the way, the SLA battery only powers the motors through the Sabertooth 2x25...so I would normally have the kill switch off when I'm charging the SLA battery, since I don't want the robot to go anywhere anyway. But if the kill switch is on and power is going through the battery to sabertooth, it'll likely overshadows the 2 amps coming from my charger anyway (with the motors running). So that said, assuming my battery didn't totally explode, the worst I can expect is my robot to just rip itself away from the power socket! I would just have to worry about a voltage spike damaging the electronics of the Sabertooth should the robot really pull itself out the socket while power is going into the Sabertooth.
So assuming the way you explained things, Soren, the battery shouldn't explode. That's a relief! If the motors are running and its pulling more than 15amp from the charger, the fuse on the apparatus will go out and the battery charger isn't damaged and no fires start. (I also have a fuse on the robot).
