Author Topic: Servo input voltage question  (Read 3449 times)
Offline pos3idonTopic starter
« on: April 02, 2009, 08:33:31 PM »
So I am working on my first project and I could use some advice.
I am using GWS servos which seem to require 6v input from my battery, however the batteries I have on hand are 9.6v so what is the best way to step down the voltage?  Should I use a regulator?  If so which one?
Thanks so much for the help :-)
Offline pomprocker
Re: Servo input voltage question
« Reply #1 on: April 02, 2009, 11:15:42 PM »
use an adjustable regulator with some resistors to give the servos their max allowable voltage.
« Reply #2 on: April 04, 2009, 12:40:47 PM »
I'm just begining so do you think a product like this one would work for me?
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=3735
I know the question is really basic but I'm working on a very tight build budget so I don't want to fry any components or end up with ones that wont work for me :-)
Thanks for the help
Offline ArcMan
  • Mmmm... Plasma
« Reply #3 on: April 04, 2009, 02:42:42 PM »
That unit will work just fine.  Just make sure your total servo load doesn't exceed the 3A rating.
« Reply #4 on: April 04, 2009, 02:55:03 PM »
one more question,  I just looking a little closer and it said that it would work with "2 to 5S Lipoly pack." Does this mean it will not work with NIMH or NICAD batteries within the specified voltage range?  I know the connectors will be wrong but I figure I can put on new ones.
Havn't worked with Lipoly batteries before so I'm a little confused thanks :-)
« Reply #5 on: April 04, 2009, 02:59:49 PM »
nope most servos will work with any battery as long as it has the juice.
Offline ArcMan
  • Mmmm... Plasma
« Reply #6 on: April 05, 2009, 06:37:37 PM »
Yea, they just give that spec for folks that don't realize that each LiPo cell is 3.7V.  It just means the input voltage range is 7.4V - 18.5V.
« Reply #7 on: April 06, 2009, 01:22:16 AM »
servos can take 7.4-18.5V? i thought they had a limit of 7.2? or do these servos have some werid requirements?
Offline ArcMan
  • Mmmm... Plasma
« Reply #8 on: April 06, 2009, 01:02:48 PM »
It's not a servo.  It's a BEC.
« Reply #9 on: May 07, 2009, 06:34:55 PM »
You should buy new lower voltage batteries. A switching regulator can probably handle the current and not hurt you efficiency-wise, but I wouldn't recommend it.
