Author Topic: I have found something very useful...  (Read 3241 times)
Offline galannthegreatTopic starter
« on: April 05, 2009, 04:11:05 PM »
To all people who want to make AVR programmers.
I have recently found a bunch of old IDE HDD connectors and realized that, "Hey, I can use these as cables for the programmer, 10 pin and 6 pin!!!".
So just so you know... if you are looking for an apropriate connector, you can use these. (I know almost everyone has them) Just cut them down with a small hack saw (go very slowly so you dont start to melt through the plastic) or a hot knife, so pretty much anything you want to use to cut them would probably work.
Hope this helps  ;) ;D
Kurt
Offline vialick
Re: I have found something very useful...
« Reply #1 on: April 05, 2009, 09:53:47 PM »
I found it useful to use a pair of pliers to remove the pins inside the header before cutting it (though this was just with female header, not sure how it will work with old IDE cables [they look like they use more-or-less the same structure])
Offline MrWizard
« Reply #2 on: April 06, 2009, 05:34:58 AM »
I use to detach these cables with a stanley-knife and heatup the cable on the connector with a lighter (not burn !), just make the isolation soft and they will come off nice and easy.
« Reply #3 on: April 06, 2009, 01:07:55 PM »
It worked very well for me, I'll get a pic up soon of it with the whole programmer.
Kurt
Offline GearMotion
  • Helpful? 24
    • CircuitGizmos
« Reply #4 on: April 06, 2009, 03:30:40 PM »
These are the same class of connector. Insulation-displacement ribbon connectors, dual-row one-tenth-inch on center. Hard drives and floppy drives used them.
Some old PCs had 10pin connectors like this inside for serial port connections. If you find a couple of those cables, then two of them together would make a 10-pin AVR programmer cable.
Offline GalacticNerd
« Reply #5 on: April 07, 2009, 04:03:17 PM »
Actually I have one of those connectors, and that's 9 pin.
Offline GearMotion
  • Helpful? 24
    • CircuitGizmos
« Reply #6 on: April 07, 2009, 04:10:50 PM »
This: 9 pin serial connector on one end, 10 pin insulation displacement connector on the other. The 10 pin IDC is one of the two AVR ISP cable options.
Offline mArKhAo
  • every moss and cobweb
« Reply #7 on: April 07, 2009, 10:57:56 PM »
very usefull huh..  ;D
i also use this as a connector(jumper) etc..
scars of a failing heart
