Squirrels have fuzzy tails.
Those are all ground connections. The symbol is a ground symbol. Those connections would all be connected together.That is an ugly schematic with parts upside down, sideways, and pins not labeled. Plus in an RF circuit the capacitor types should be called out at the very least.ETA: My point in complaining about the schematic is that there is more to circuit design than replicating a schematic. This GIF image does not capture many of the things about this design that need to be documented.
Quote from: GearMotion on April 09, 2009, 11:26:21 AMThose are all ground connections. The symbol is a ground symbol. Those connections would all be connected together.That is an ugly schematic with parts upside down, sideways, and pins not labeled. Plus in an RF circuit the capacitor types should be called out at the very least.ETA: My point in complaining about the schematic is that there is more to circuit design than replicating a schematic. This GIF image does not capture many of the things about this design that need to be documented. Yea you are right, I searched the pinout datasheet for two of the chips, and they are upside down, unfortunately this is the best schematic I could find, that didnt require SMT, MCUs, or programming, thanks thought.Also what do you mean "called out" capacitors? The cap values are labeled.
