Author Topic: Schema to check  (Read 2281 times)
Offline KlonTopic starter
Schema to check
« on: April 30, 2009, 02:52:10 AM »
Hi again
This is my first schema ever, so please help me and point mistakes. it's for an assignment, I don't know much about how to design hardware. Please, dont be very cruel for a noob, I'm still not sure how this stuff works ;) I would be grateful for any advises or links.
What I need to do in this assignment is to build a device with 3-axis gyro (in this case, one single and one double axis) and a 3axis accelerometer. It will be used on a model aircraft, to research the forces occurring on the plane. It will store data on flash memory, and. well.. that's it ;)
Links to parts:
microcontroller
http://www.sparkfun.com/commerce/product_info.php?products_id=216
Flash
http://www.sparkfun.com/commerce/product_info.php?products_id=544
gyro1: 300 deg/sec
http://www.sparkfun.com/commerce/product_info.php?products_id=8955
gyro2: dual, 500 deg/sec
http://www.sparkfun.com/commerce/product_info.php?products_id=698
accelerometer, 6g
http://www.sparkfun.com/commerce/product_info.php?products_id=252
« Last Edit: April 30, 2009, 03:36:32 AM by Klon »
Re: Schema to check
« Reply #1 on: April 30, 2009, 04:34:29 AM »
Cannot check the schematic, since it's not readable.
Offline hazzer123
Re: Schema to check
« Reply #2 on: April 30, 2009, 04:44:47 AM »
Did you draw this in paint??
You should really learn to use Eagle for making schematics -http://www.cadsoft.de/.
That said... its an impressive schematic if it's from paint. Must have taken a while!
www.icrobotics.co.uk
Re: Schema to check
« Reply #3 on: April 30, 2009, 05:25:15 AM »
http://img403.imageshack.us/img403/306/schemaj.jpg
that's the link to full res.
yea, i made it in paint, im using my uni's pc and can't install any external apps :/
ok, as i don't know much about electronics, this is a description of two tiny issues of my schema
5 pins from 3axis accelerometer connect to microcontroller- one each for x,y,z axis, one to set it to sleep mode when required and one to GS2 pin (it sets acc. for 6g sensitivity, GS1 is for 3g) - only GS2 is connected, can it stay this way or do I have to connect both GS1 and GS2?
I connected 2axis gyro and flash to RB pins, but accelerometer and 1axis gyro to RA pins. I suppose that it might be wrong, but I don't know if there is a difference between these pins and I cant find the answer in the datasheet.
damn, i wish i had more time to read more, but they give us far too many assignments at once :[
edit/ aaight, i discovered that i need to connect PD pin to gyro as well to be able to set it into power-down mode.
and another issue - i cant find any information about power consumption of gyros, has anyone got any idea? :/
« Last Edit: April 30, 2009, 07:39:00 AM by Klon »
Re: Schema to check
« Reply #4 on: April 30, 2009, 12:36:35 PM »
The pages you linked to contains the datasheets where such info is!
LISY300AL = 4.8mA (typ.).
IDG-300 = 9.5mA (max.) quiescent.
